Trying to create a node into to my system repository for reuse later on, but each time I'm getting an error.
Using Ventux 5 .2.0.138 Thoughts?
Thanks all
Greg
error says
Repository Error
Create Item Error
Couldn't write Selection Archive / Object reference not set to an instance of an object
System Repository node creation error
Re: System Repository node creation error
Seams that once I "Merge to Container" my function nodes in the Container panel that is when I get this error. If I copy paste the nodes into the Repository before Merging them it works with no error, but I want this node to be locked.
Any more thought?
Greg
Any more thought?
Greg
Think I solved it...
I was using the Ctrl+C / Ctrl+V cut and paste method to try and create these repository content nodes.
But I just tried dragging and dropping with the Ctrl held down and the Content node was created.
FIXED
Greg
FIXED
Greg
