Hi all,
how can i get a cubemap from one layer to the other??
Thxs and greets
CubeMap layer
Re: CubeMap layer
Hey Christian,
In V5.1 and higher the RenderCubeMap Node has a texture output property. You can expose that property and bind it to the Input of e.g. a Skybox Node in the other layer. Change one of the Texture Property Groups to an Empty Texture Property to do that:
Hope the RenderCubeMap Node is what you meant.
Stephen
Stephen
Re: CubeMap layer
Hi Stephen,
yes, you are right
Where is the Cubemap texture stored? If i expose it i have no access outside of the container. i just can bind it to a string but not to a file input of a texture ;(
Maybe i am to tired ;(
Greetings
yes, you are right
Greetings
Re: CubeMap layer
You can not bind it to a File Property!!
You have to bind it to a Texture Property. Create a Material and then create a Material Stage with a TextureProperty-Empty.
Re: CubeMap layer
FYI:
Since you want to use the CUBEMAP you must use a "Material Stage -> IBL Specular".
The IBL Specular is the only stage that has a "Cubemap / LongLat loader"
So, basically follow the guides from Daniel and Stephen but use the "image based lighting - specular" stage.
You can still map the TARGET to anything else than "Specular/ Specular Light" !
Next Thing:
If you use a MIRROR:
The mirror has a Texture Output as well. To make use of the MirrorTexture you would need a Material, Load it into the Empty Texture Property BUT:
For Mapping you would need to select "2D Mapping -> ScreenAligned".
Hope this lights up the topic a bit
Best RegArts
Next Thing:
Best RegArts
Re: CubeMap layer
Hi Daniel,
as i said: to tired
Thx, this was the hint
Dee: Thx... will check
Greets
as i said: to tired
Greets
Re: CubeMap layer
But is it possible to save that texture? if i try to save it with a textureSaver it sores just a transparent cross on a black background
Greets
Greets
