This problem occurs also in V4, never noticed that.
see attached vza (rename zip to vza)
Can't select specified image by 'current'-input of stringsplitter, path is not working.
Although there are obviously simpler solutions, I need the StringSplitter-Node.
This works in V3, but anymore in V4+5 ...
(for now I transfer old presentations to V5)
Help is welcome
Stephan
StringSplitter-Node incompatibility V3 - V4/5
- problem_DIR-StringSplitter.zip
- (12.33 KiB) Downloaded 182 times
Re: StringSplitter-Node incompatibility V3 - V4/5
hi stephan,
this is easy. from v3 to v4 the dir node output has changed to a string array. so instead of a string splitter you need to use a string array indexer!
DANKE Christian!
I inserted this node yesterday temporarily, the problem is you have to define the size of the array before. Number of input elements changed dynamic.
Gruß Stephan
Gruß Stephan
... it's working (defined 1.000 elements), but in my opinion it's not a clean solution
You don't need to define that. you can use size of 1 and just adjust the offset
an array indexer with size of 1 can handle any size just has one output
greets
greets
FINE , thanks
(info is not in ventuz help ...)
Stephan
Stephan
