Ventuz Cinema 4D import animation
Posted: 03 Nov 2016, 14:05
by MouseOver
Hi I have tried to import my Cinema 4D animation to ventuz in various ways but nothing seems to work.
Since i use cinema 4d I tought it would be great to prepare everything inside Cinema and then use the live link. It didnt work with the very large scene i have (around 40 Tausend Polygons and some simple animations). Is there any limit with polycount for the cinema link ( the geometry import works, the animations dont).
I also tried with a short scene and didnt work neither, I am "creating the animation" between frames 0 and 150, and then moving the slide on ventuz but nothing happens. (I dont know if i have to check the animation field, any of the youtubevideos tutorial are checking it ). am I doing something wrong or missing something?
pd. i also tried with a dae geometry import, the geometry gets imported but when sliding the frame field in ventuz nothing happens.
I am using c4d R17 and ventuz 5.2.0.138 R15415
this is the scene i am using:
Re: Ventuz Cinema 4D import animation
Posted: 03 Nov 2016, 18:14
Posted: 04 Nov 2016, 10:50
by MouseOver
Thank YOu, i downloaded ventuz 4 and after trying for a while now works. But, ventuz 4 seems to not being able to import an animated geometrie build with quads( this means i have to cheked the triangles box in cinema while exporting ... this duplicates all my polygons... and they are already a lot ) is that normal?
havenĀ“t experiment till now, but do ventuz 4 and 5 import and scale DAE the same?
thanks!
Posted: 11 Jan 2017, 10:10
by mathias
Hi, it seems, that the object Live link Animation Feature in the Mesh Loader is just working with animated Cinema Deformer Objects. I haven't tried
MoGraph yet. You can animate an Explosion but not a Rotation of an object. I couldn't find this in the Manual.
Is there really no way to animate rotations or movements in the Live Link Mesh Loader?
Mathias
Cinema 4d 18 and Ventuz 5.02.01
Posted: 11 Jan 2017, 10:47
by Christian Krix Schmidt
Hi MouseOver.
Yes, it is normal that everything is in triangles. Funny enough, quads and polys are actually a helper for designers but with the GPU everything is calculated in triangles. You should not use the exporter triangulation function. Instead use the command from within Cinema4D to get the best results. Plus you can see if everything is looking as intended before exporting.
Posted: 08 Feb 2017, 15:00
by gaz99
mathias wrote:Hi, it seems, that the object Live link Animation Feature in the Mesh Loader is just working with animated Cinema Deformer Objects. I haven't tried
Mathias
I am also looking to use the Live Link to animate objects rotations/movements but having the same problem where only things like explosions come across and not the rotation and position key frames. Did you find a solution for this? Is it possible?
Gareth
Posted: 08 Feb 2017, 16:41
by gaz99
Looking at the thread Dennis suggested, If i export my Cinema 4D object with animations to a .dae and then import into a Ventuz 4 project it generates the animation timeline which i can use to control the animation and it has the position and rotation values. To get this in Ventuz 5 I have to export from Ventuz 4 as a Scene Archive (.vza) and then import into Ventuz 5 as the mesh loader in Ventuz 5 doesn't generate the animation timeline.
Can this feature be added to Ventuz 5 so I don't have to go through the tedious process of importing into Ventuz 4 just to export and the re-import into Ventuz 5 ?
Does it already exist ?
Gareth
Posted: 09 Feb 2017, 10:31
Hi Gareth,
since we changed the importer completely to Assimp for V5, we have issues getting the correct animation curves into V5.
We are working hard to get that back to you
We are sorry for the inconvenience!
reg
Arts
Posted: 09 Feb 2017, 17:57
by gaz99
Dennis wrote:Hi Gareth,
reg
Arts
Hi Dennis,
Do you have a timescale for when this functionality will be back?
This feature is critical to a project I am working on and creates problems in managing any changes that happen to the models we receive. For example, any time we have an updated model we have to go through the process of importing to V4, then exporting and re-importing to V5. On top of this process, any extra nodes and logic that we create that are sub nodes of the imported mesh will have to be moved from the old mesh to the new mesh. In addition to this anything that uses any mesh axis will have to un-linked from the old mesh and re-linked to the new mesh.
This is going to add a massive impact to our schedule as this process will need to be repeated each time we receive new assets.
I hope you can appreciate this will be very time consuming, please advise on a timline for a hotfix, or if there is a better process we can follow please do share it!
Gareth
