I was wondering if there are any specific settings Ventuz uses when rendering to disk with a particular codec?
I have a pixel space of 9,600x1200 pixels. If I output an animation as a HuffyUV animation at 60fps from 'Render to Disk', when re-imported as a movie file into Ventuz, its plays without skipping. Just what I need.
If I output the same animation as a Quicktime Animation of course this will not play within Ventuz. Taking it through myFFmpeg ( a nice Windows front end) and converting to HuffyUV gives me a file that does not play at all smoothly.
Are there any specific settings that Ventuz automatically uses when outputting to video files with the HuffyUV codec? Does anyone have any tweaks or settings that can be applied in myFFmpeg?
Render to Disk codec problem
Re: Render to Disk codec problem
Answering my own question having rendered 30 different versions with varying HuffyUV settings. I found a few that are performing nicely.
For those who need video playback, and need to make HuffyUV files there is a great Windows Interface called myFFmpeg that is an interface to FFmpeg encoder. You do not need to use command line interface. Installing the HuffyUV codec is relatively straight forward. Just Google it. There are some videos on the web.
This Codec makes big files but I am using an NVME 512Gb Samsung Pro that is delivering me some great movie playback.
