Validate / Match argument in Event node
SamTheSwede
Post by SamTheSwede » 26 Aug 2014, 20:15
Wouldn't it be a great thing to be able to set a "match argument value" in an event node. If the match argument value matches the incoming argument the event is fired if a new validate switch and the use incoming argument switch is set?
To me it would be very useful, but, maybe someone else has a good solution for this?
// Sam
Daniel Willer
Re: Validate / Match argument in Event node
Post by Daniel Willer » 27 Aug 2014, 09:31
Hey Sam
You can use the Event dispatcher or Multiswitch Node to trigger an event based on the Argument or you write a simple Integar Expression connected to the Shot of an Event node.
Cheers!
Daniel
SamTheSwede
Post by SamTheSwede » 28 Aug 2014, 10:27
Ahh, thanks Daniel!
The best solution seems to be the Event dispatcher, however I would still wish for a Custom model in the Event dispatcher!
The thing is, I have data coming in from another system with event numbers like 401, 512, 611 and numbers like that.... I've worked around using a ENUM node in front of the Event dispatcher, but a custom model would be even nifitier!
// Sam
Post by chriss0212 » 28 Aug 2014, 20:06
can b done easy with a counter...set the end to the argument you like and reset the counter with the event and argument...if the right argument is fired the counter will reach the end and fire end reached...reset the counter one frame later with a zero as event argument ;)
chritian
SamTheSwede
Post by SamTheSwede » 28 Aug 2014, 20:24
That's a nice workaround, Christian! Thanks for the tip!
:idea: :D
// Sam
