Fullscreen reduced unexpectedly to icon
PostPosted: 09 Feb 2017, 14:36
by pasto
Hi all,
I have this kind of problem with the presenter runtime. Sometime it suddenly reduced to icon (virtual fullscreen is off).
This happens with a cluster setup of two machines 4x4 hd output where randomly one machine or the other do that.
The OS is Windows 10.
Did someone already encountered this kind of problem?
Any hint would be very appreciated.
A
Re: Fullscreen reduced unexpectedly to icon
PostPosted: 13 Feb 2017, 16:04
by Christian Krix Schmidt
Hi there.
I had that behavior on my Windows 10 laptop when it first launched as well. I quickly double checked with the manual as well:
"Disable Notification Icons, they can catch the focus and force the Ventuz Runtime to minimize."
Hope that helps.
PostPosted: 20 Feb 2017, 10:44
A small hint on that side:
You can disable and force these stuff like the "Windows Defender messages, Action Center, Notification Tray Messages etc pp" to stay away by changing the settings with the "Group Policy editor" ...
Please use this at your own Risk!
This a windows 10 tool, with common scripts collected under a "control panel" like...
To fire up the Group Policies Editor simply type in your w10 search "edit group policy":
To disable or remove the notifications and action center simply follow the following route shown on the screenshot. This will not remove the "balloon tips" or Tray Notifications. These can be found also either in the User Config or Computer Config.
Its worth the time to crawl trough the lists to get a clue about what can be configured and disabled... especially for "playout machines" :)
Please again: USE THIS AT YOUR OWN RISK!
