Ventuz crashes when using VS2015 for debugging
Postby Luke47921 » 23 Mar 2016, 11:02
When debugging scripts using VS2015, I've noticed two events that make Ventuz crash nearly 100% of the time. The first, when the just-in-time debug window pops up, if you select no to using the selected debugger, Ventuz will crash. Secondly, if you are already debugging the script, and you stop it prematurely, this will also cause Ventuz to crash.
Luke47921
Return to Bug Reports
