Database‘s Query bug
BaldwinHu
Post by BaldwinHu » 29 Apr 2015, 12:26
Hi,guys,i have found a bug,it is about database's query.
describetion:
if i restart my project,i can use axis node as unual(like change its position x),but if i press Query's Execute property(the binding is right,i can get data from db),i will not chage axis node's properties,no more than this node,all other node will not change,i must restart my project . this is very bad for me working with ventuz,so i hope you chack it and fix it quickly,thank you very much!
BaldwinHu who from China!
My E-mail address is 330223362@qq.com
Re: Database‘s Query bug
Post by chriss0212 » 29 Apr 2015, 16:24
maybe it is not a bug of ventuz....maybe a bug in your db query?
i am not sure if database querys are async...sot it could be, that your query brings ventuz to stall or crash?
BaldwinHu
Post by BaldwinHu » 30 Apr 2015, 12:37
hi,i have tested it in a new virtual machine,this question is gone,i don't know what result it,so i try another database(mysql) in my real pc(which have this mistake),there is no this error,so i think this error will appear when you use access db in a special system?the symptom is that i can not change all node's value by pressing and dragging,but i still can change it by double-clickking.
