Exposed Interfaced swapping colours
joysprod
Post by joysprod » 25 Feb 2015, 18:55
I have a strange problem happening with an interfaced container when the contents are updated via the "Paste Container Content".
Four containers (1-4) all identical, have a text field, a text colour and a diffuse material value exposed.
See different screen grabs of before and after applying "Paste Container Content", and the scene file
Exposed Interface.vzs
(13.82 KiB) Downloaded 282 times
The text colours get swapped for the rectangle colours although given different names.
Götz_B
Re: Exposed Interfaced swapping colours
Post by Götz_B » 26 Feb 2015, 09:55
the message log tells you the answer:
Warning: No_3 (Hierarchy Container): Duplicate Property Name detected Colour
When you use Interface Container you have to make sure that you use unique names. The category name doesn't count!
Otherwise it may happen that Ventuz can't distinguish.
Regards,
Götz
joysprod
Post by joysprod » 26 Feb 2015, 11:37
Thanks for that. I didnt realise that the category name didnt count.
