touch translation reset
Post by chriss0212 » 22 Oct 2014, 06:18
hi....
dont know if it is a bug...but defenitly not a feature...
if a create a touch translation node and disable reset on load...it will reset on load when i start it as runtime...even in director mode!
is it possible to change this?
Daniel Willer
Re: touch translation reset
Post by Daniel Willer » 22 Oct 2014, 10:20
Ups sounds wrong. I will write a ticket for that.
Daniel
Götz_B
Post by Götz_B » 22 Oct 2014, 11:59
Tach!
Did you change any of the settings of the touch node?
Cause when i drag it to a fresh scene with just a rectangle behind and only disable 'reset on load' without changing anything else, it works as expected...!?
Grüße,
Götz
Post by chriss0212 » 22 Oct 2014, 13:37
hi götz,
have you checked it in runtime?
open runtime...move rectangle...close runtime..open runtime...and rectangle is still moved?
Götz_B
Post by Götz_B » 22 Oct 2014, 14:28
Ah, ok. No, not between two runtime starts.
It just stays at the position where you saved your scene in Designer.
I think we dont save anything when you close the Runtime...!?
Post by chriss0212 » 22 Oct 2014, 19:30
i think so....and thats the problem! i thought that maybe in director mode it coul work!
it would be realy helpfull!
Götz_B
Post by Götz_B » 23 Oct 2014, 10:30
We will check. Daniel already wrote a ticket.
Post by chriss0212 » 24 Oct 2014, 06:28
it seems, the nested scenes by scene port wont be saved two if you close the main scene and dont save the nested scene itself!
had a big trouble because of it in a very chaotic rehearsle/ setup day....but at the end: show was fine!
we made a projection mapping in more than 50 cubes ;)
