Shader sampler border setting override
lerou
Post by lerou » 23 Nov 2014, 20:03
this is a tricky one. In a nutshell, some settings performed in shader A override settings for shader B. This is Ventuz 4.05.02.
Take a look at the image:
Shader A sets the sampler settings hardcoded:
sampler TexSampler : register(s[0]) = sampler_state
  AddressU = Border;
  AddressV = Border;
  Filter = Linear;
Shader B is in a parallel part of the tree. In the texture node (not in the shader itself!) the settings are:
  • Mag/Min: Point
  • U/V/W-Filter: Wrap
However the settings from Shader A override those done in the node in front of Shader B. Permanently! That means even after deleting the Shader Node A the effect remains. You'd have to save, close and reload in order for those overrides to disappear.
This goes even further:
  • Close all scenes
  • Open Scene bug_002 -> it looks as expected
  • Open bug_001 (make sure you haven't saved any changes there before)
  • Switch back to the still open bug_002 -> the settings here are overriden
greetings,
the tree with both shaders
this is how the render output looks after the values are overriden
this is how the render output should look like
lerou
Re: Shader sampler border setting override
Post by lerou » 23 Nov 2014, 20:04
here are the scenes.
greetings,
bug_002.vza
(23.68 KiB) Downloaded 498 times
bug_001.vza
(23.92 KiB) Downloaded 470 times
Post by Karol » 25 Nov 2014, 10:39
I opened a Bug ticket for this.
