Touch inside not working with multiple touch nodes
Posted: 24 Feb 2017, 10:14
When I've one circle object with a touch button node in my scene, the touch inside property works perfect.
When I've another circle object in the same scene with a touch translation node, the touch inside property of the first circle doesn't work anymore as soon as I drag the second circle inside the first circle.
I want to detect when the second circle is inside the first circle. I can calculate it by comparing the x-y position value's of the second circle are within the area (bounding volume) of the first circle. But I need it more precisely. The intersection type should be mesh.
See attached scene.
What is the best way to solve this.
Kind regards
Rogier
See attached scene.
Kind regards
Rogier
