Hi, all:
I am new to Ventuz 4 Designer. I am using the Text Effect "Alpha Effect" to make text on a Slide in a Slide Manager look like it is fading out when I go to the next slide. It fades out fine, but always using a specific direction that I'm guessing is set by the "Direction" parameter in the Alpha Effect (choices are NearToFar, FarToNear, Center, and Random). I don't want this directional effect. I just want the text to fade out. I'd appreciate any direction on how to do this correctly.
Thank you.
Don
Alpha Effect
Re: Alpha Effect
Hi there,
You can just use an Alpha Node to fade out the text.
Daniel
Daniel
Re: Alpha Effect
Hi, Daniel:
Thanks for the reply. What I am saying is that the alpha node seems to add a directional wipe to a dissolve. I'm trying to find out how to remove the wipe part.
Don
Don
Re: Alpha Effect
Hi!
You should use the 'Alpha' node from the Color category not the 'Alpha Effect' node!
