Touch Translation/Transformation + Button
I'm trying to built an application which can use TouchTransform and TouchButton on top of each other, much like its done on any touch device (e.g. Android)
Imagine a bunch of buttons, to many to fit on a screen. When you drag your finger across the screen it will scroll through the 'menu' - when you tap one of the buttons it works like a button - sounds simple, but it's not because touch nodes are exclusive.
I managed to create this behaviour with a combination of TouchTransformation and the old MouseOver node from Ventuz 3.
Basically it checks if the touch is inside the geometry, and if the TouchTranslation doesnt detect a certain threshold of movement, it sends the event on touch release.
This works great with a mouse, but the application is intented for a TUIO touch device, which doesn't give input to the MouseOver node.
Did anyone tried something like this before or has an idea on how to make it usable with touch displays?
ps.: Why did you remove the MouseOver and HitTester in Ventuz 4? Those were great, and pretty much the only kind of non-exclusive collision detection we had ;(
Re: Touch Translation/Transformation + Button
To late to edit, but after posting i thought of this:
Would it be possible to add another property to the interaction nodes to toggle them from exclusive to non-exclusive (with default to exclusive, so there are no compatibility issues). This would add so many possibilities to handle different touch conditions with our own logic.
hi schub
- hittester: you can export a vza with a hittester from v3 and import it into v4 and...you have a hittester in v4
- there is a script around to get acces to the tuio data! so: no problem to combine tuio with the hittester
- if you dont like the script: with the tuio toolbox from tobias schwirten you get the first i think 10 points as osc data!
https://code.google.com/p/tuiotoolbox/
thanks chris, that looks like a possible workaround.
I found this thread, Alex was talking about a simpler script he posted but i couldn't find it.there is a script around to get acces to the tuio data! so: no problem to combine tuio with the hittester
hi schub
the script is in the vza from alex
yeah, but i wondered where the small version is that he mentioned
P.S.: Before anyone (chriss, hint, hint) complains, yes, this is 450 lines of code/doc as it already handles a couple of problem cases. The first basic implementation I had was way shorter and easier to understand (and done in under an hour), but I decided to put everything into a separate thread so the delay is minimized, clean up a few things, ...
I just learned about the upcoming TouchRipple node!
This will make it 10x easier, can't wait for v4.1 :D
In the next Ventuz release there will be a TouchRipples node that provides the tracked touch points
Hi Alex, those are good news.
Does that mean, if I place a button on top of a translation node and I start the swipe on said button it will move the translation, but also fire the buttons singletap event?
If yes, it would be very easy to do the additional logic for handling the unwanted triggering.
By the way, we don't use the button events for touch applications, but a more forgiving touch-pressed to event-shot setup.
For now Im trying to do a workaround with proxy buttons in another hierarchy tree, that are actually touch translations.
Their Y-values get added to the menu axis, but dont update the proxy buttons axis until the touch is released.
I tried to do the double translation in one tree, but the menu was flickering while swiping.
For more on this, please look at the new Touch Proxy node (and associated help files)!
