I am using a stream "h.264 using rtp over rtsp over http" (Devices:AXIS F44 with AXIS IP Cams) with the stream-node and get approx. every frame this message:
ints change, but are repeated....Warning ffmpeg streaming: move FirstTick to 21493 (127194007)
What does this warning mean?
And how to STOP the node spamming the warning vlog? (Next log level is error... and i don't want to use just error & fatalerror for my logging,...)
nevertheless the stream seams to run ok, but I need to be sure.
Thanks!!
