Hi All
Has anything changed in Midi input from V2008 to V3?
I have a CtrlChg (Control Change) node that doesn't work when it is connected to an Integer for channel number and a container information node to get the controller number.
If I create an identical node and set the same properties, it works
If I select just the single node and copy it out, the copy works
If I copy it with all of its providers and then detach them to it looks the same as above - it doesn't work!
Seriously weird.
Carl
MIDI in Ventuz 3
Re: MIDI in Ventuz 3
hi carl
same problem if you deselect the midi device and reselect it again?
chriss
chriss
Found and fixed!
Comes with the next update!
