Would it be possible to move a whole family in the Content window even when the items are nodes are collapsed?
How many times have you move a collapesed item then expand it later on and all your nice layout has moved because the other items in the collapsed tree reside in the origonal position then everything moves.. doh!
It really would help keep some of those crazy diagrams in the content widow under control
Moving Families in the Content window
- Joe Styles
Joe Styles
Kinetic Pixel
Kinetic Pixel
Re: Moving Families in the Content window
hi,
which version are you on, cause if I do this on 3.061 I encounter no problem with it, maybe i got you wrong...
Im moving a whole family while everything inside is collapsed, when I expand - everything has the same position inside the family window as before the move.
- Joe Styles
Hi Oliver,
Yeah I think I have worked out what was going wrong now.. it was down to moving a single node that is part of a family and that family is comply collapsed.
I have attached a sample. If you expand the family connected to that axis, you will see they are all nice and close together. Collapse it again and move it and the other nodes stay where they are. I can see why the content window behaves like this but unless you know to not move a single node collapsed in a family you do end up with some crazy layouts.
Joe
Joe
- Family Moving.vzs
- (5.58 KiB) Downloaded 393 times
Joe Styles
Kinetic Pixel
Kinetic Pixel
Maybe a solution would be to be able to block the position of nodes inside the content window.
robert
robert
