Offseting XY Touch Coordinates
LuiZbim
Post by LuiZbim » 29 Jan 2014, 19:47
Hi, my current project demands me to stretch my display between two monitors (a touch one and a normal one).
However after doing so, the touch calibration becomes useless because it tries to cover both screens area (while I need it only on the touch screen). I couldn't find a good way to offset or customize my calibration in Windows' options...
So I'm hoping anyone can tell me if there's a way in Ventuz to offset or adjust the values the touch is receiving and "trick" the computer so it gets calibrated artificially. Thanks in advance!
joysprod
Re: Offseting XY Touch Coordinates
Post by joysprod » 31 Jan 2014, 16:25
Hi Luizbim
Not easy to do in Ventuz - if at all possible?
I came across these guys - http://touch-base.com/download.asp
You can even download a test driver limited to a 100 clicks to test your set up.
Allows you to have a touch monitor in a cluster and have correct coordinates.
LuiZbim
Post by LuiZbim » 31 Jan 2014, 17:31
Hello Peter, thanks for doing some research, I've already requested a driver, hope it helps.
I'm still learning a lot from Ventuz, maybe you can help me understand if a cluster of machines would let me interact with my presentation the same way as my current multi-screen display, and WITHOUT stretching the desktop.. as it is the main problem.
Thanks again :)
Post by chriss0212 » 02 Feb 2014, 09:16
hi
maybe you can try the tuio toolbox from tobi. afaik it can scale the tuio x/y coordinates what would solf you problem ;)
https://code.google.com/p/tuiotoolbox/
LuiZbim
Post by LuiZbim » 03 Feb 2014, 19:04
First, thanks Christian and Alex!
I haven't been able to test the TUIO toolbox yet, but I think a free driver/software like that is my best option as Alex says.
After trying many options, asking people and doing research, I became aware my request was REALLY specific.. that's because the hardware and displays we will use to show the presentation are even more specific :/
Alex, I have both Ventuz 3 and Ventuz 4 PLE licenses, but I did the project only in Ventuz 3, so I'll take a look at the Ventuz 4 new Render Settings.
However, I managed to calculate the touch offset by using some Clipping Nodes but it's still a tedious and incorrect way of solving it, if nothing works maybe I'll contact your sales guys Alex :D haha.
Thanks again!
TobiTobsen
Post by TobiTobsen » 06 Feb 2014, 13:57
Japp, if you are using TUIO, the ToolBox should be very helpful for your setup...
Tobi
http://www.radar-touch.com
http://www.prime-touch.com
