Create linked content in another hierarchy container.
flaboratoirium
Post by flaboratoirium » 25 Dec 2013, 17:18
As shown in the image i would like to create a linked reference of "unten links" INTO the "oben" hierarchy container.
tried all "move while holding" commands, even tried "ctrl+shift+v" to paste, but that seems not to do anything apart from
freezing ventuz for some seconds. isn't that simple task not possible after all?
Re: Create linked content in another hierarchy container.
Post by chriss0212 » 27 Dec 2013, 11:02
hi flabo
it seems you are trying to connect apples with oranges ;)....this is not possible.
if you want to archiece, that you have to axes with the same value you can use get world and set world but with 1 frame delay! or you bind all INPUT properties of both axis with no delay!
flaboratoirium
Post by flaboratoirium » 27 Dec 2013, 23:15
well i tried to move the linked instance INTO the "oben" container to keep things well organized.
somehow i do not understand WHY this is not possible. why has the reference to be in the same hierachy?
If it is just a copy of something already created in the memory it should be no problem to access this
copy from other containers as well?
TobiTobsen
Post by TobiTobsen » 28 Dec 2013, 17:17
Hey,
try this: select your axis "unten links", press strg+c.
Enter your hierachy container "oben", select the "content" window (not the hierachy window), press strg+v.
You should see now your axis as an unlinked Item in the hierachy window.
Not sure if this is what you are trying to do?
Tobi
http://www.radar-touch.com
http://www.prime-touch.com
flaboratoirium
Post by flaboratoirium » 28 Dec 2013, 18:20
hi and thanks for your advice, but that way i just get a "copy" of my "oben links" axis.
i just want to have a linked reference of it. just like dragging "oben links" in the hierachy with the right mouse button
and selecting "link here". the only difference is that i want to have this linked reference INSIDE another hierachy container
(it just has to be there i dont need any specialy new input bindings or stuff...)
cheers, stefan
Post by chriss0212 » 29 Dec 2013, 22:44
hi
this is not how it works ;)
please take a look in the help and search for containers and interfaces.
duisburg and wuppertal...not so far ;)
uuhhps...you are based in wuppertal? pease send me a pm ;)
greetz and "guten rutsch"
