Binding several nodes simultaneously
resetna
Post by resetna » 28 Oct 2013, 09:21
Dear, friends!
I am wondering if there is any opportunity to bind an input (for example, event INVOKE) to several nodes simultaneously. Very often there is a need to link a particular property to huge amount of nodes, and it's kinda tricky... I still can not find any hotkey for that. Something like left clicking while holding a right click button does not work, as it does for container nodes proparties.
Thank you for any advice!
Re: Binding several nodes simultaneously
Post by Karol » 28 Oct 2013, 10:09
It's possible to bind multiple Input properties of the same type to one single Output:
Multi-select the nodes by Shift-LMB or Rectangle-selection in the Content Editor and bind the Input properties to the Output of another node like in the single node case.
The same applies for Method-Event bindings. The other way round is not possible: there is no fast way to bind Events of different nodes to the same Method.
resetna
Post by resetna » 28 Oct 2013, 20:37
Thank you, Karol!
My question was exactely about other way round possibility. Ok, hope this will be considered in further versions.
