Hello everybody!
Need super urgent help! Texture disappears in presenter, but works fine in designer? whats wrong?!
Scene: https://www.dropbox.com/s/r3x1luak1elci2z/New2.vza
different behavior in runtime and designer
Re: different behavior in runtime and designer
Ok I have tested it in the Presenter and it is working. The probleme could be the size of the texture it is 8k big you should go down to 4k.
No 4k is not enough. There is another strange thing, if I use only one rectangle with this texture, everything works, and if I add anything else, circle for example, it doesn't
Solved, I've divided the map in two different rectangles. But its strange anyway, it is not the first situation, when presenter works different from designer...
Could you please post the presenter.log file located at
C:/ProgramData/Ventuz
Thx for the idea with log! The reason was that I had x86 and x64 Ventuz on one comp and presenter was starting as x86 so it was a lack of memory!
