How works the undo command in Ventuz?
I did several changes to the scene, I changed some textures...etc.
Then I wanted to undo the latest command...and boom...all the latest 30 changes were deleted....
Is not possible to add an undo history to the software?
Undo
Re: Undo
hi gabriele
this is realy a big problem in ventuz 3. forget the undo function....and please disable undo in the ventuz settings!
strg+s is your friend!
Re: Undo
Undo works in the Hierarchy , The Text Editor and Script/Shader Editor.
If you Undo in the Hierarchy/Content Editor, Ventuz undos the last step in the Hierarchy only. Anything you did in the Content Editor between those steps will be undone as well. The Content Editor is basically disregarded by Undo in Ventuz. The larger your scenes the slower working in the Hierarchy gets. Undo basically saves all the changes you make each step and that requires more time if your scenes get larger. That's why experienced Ventuz users always deactivate Undo. Plus if you adapt the way you build and work in your scenes you won't need it anyway. I never missed it but then again, I have been working like this for 10 years now. (Yes, 10th anniversary of Ventuz since it's very first internal alpha production tool version is actually coming up).
The most important Undo I think is actually for the Property Editor. If you scrub through a value and you would like to revert to the original value press the right mouse button while still scrubbing. The property value will revert to the value before you started scrubbing.
By the way, PLEASE do not start a conversation or thread about wanting Undo in Ventuz like you know it from other software. Believe me if I say, we have been down that road before.
