How to show pdf?
Re: How to show pdf?
In Ventuz3 it's natively not possible.
option1
You could use a grabber card + extra pdf pc and the videoin node.
You then control the pdf viewer on the extra pc with osc or tcp.
(Small controlable pdf viewer needs to be build or buy it at stereolizeshop)
option2
Another option would be to build a tool that streams on a directshow device and thus it can be included within the video in node.
This would save you the extra pc + grabbercard. This would be the best solution.
cheers!
option1
option2
cheers!
ok, thanks.
I think that Ventuz should develop a better method to handle pdf documents. Probably it needs a big Adobe logo over the Ventuz interface...I don't know.
Pdf it's a standard format as the jpg or videos.
