I tried to run a QTVR movie in Ventuz. After putting the Ventuz´Quicktime-Nodes into my node structure I got the error: "Quicktime doesn´t support 64 bit OS"
Also the Quicktime-Node examples (F1) didn´t work after importing the QTVR movie.
But - the imported QTVR runs on my 64bit OS as standalone outside from VENTUZ.
Some experiences and tipps? Thanks.
Marko
QTVR MOVIE - 64 bit Problem?
Re: QTVR MOVIE - 64 bit Problem?
you need to use the 32bit ventuz if you want to use the quicktime nodes! quicktime is a 32bit app and can not run inside of a 64bit app!
