Before i set a absolute video path(D:\1.mp4) to the MovieClip node as the texture of a rectangle,it works.
Now i set a webserver video , just like http://192.168.0.12/video/1.mp4 which exsits on a mac apache, i can download it.however when i set the path to the MovieClip node as same as before, it does not work, MovieClip node can not transform this path to texture for use. Do i need a mid-node to convert the path,any help ?
How to set a webServer video to Movieclip node ?
Re: How to set a webServer video to Movieclip node ?
And the error msg is "14:17 2012/3/28 Error : Movie (Movie Clip Advanced): Error creating Movie Resource: http://10.0.1.100/ivision/pic/27.mov: HttpFtpSchemeManager.GetLocalFSPathCore"
Allen,
Not sure that streaming video is already implemented with ffmpeg.
Robert
Robert
The Movie Clip Adv. node is currently not able to display streamed video content.
You have to use the 'old' Movie Clip node:
http://inside.ventuz.com/2009/10/video- ... in-ventuz/
Thanks Karol, i found that old MovieClip node can only support wmv stream video and my OS is win7 64bit, on which QuickTime node does not work at all.So I use MovieClip Advance Node to Play QuickTime Video(.mov/.mp4) with absolute path, which works well.However, when I change the path to a webserver url, it does not work.Your given blog is written in 2009, i wanna know if there is some update to support the QuickTime stream video, after all old MovieClip + MovieClip Advance can do in theoryKarol wrote:Hi!
at the moment no time to check....but maybe something like this could help?
http://www.webdrive.com/products/webdrive/
http://www.netdrive.net/features.html
this is a software which should map web adresses to a virtual drive?!
chriss
chriss
Is there any possibility of this being fixed in the next release? We have a project at present where I need to load MP4s using HTTP, and neither the MovieClip or MovieClip Advanced node support this functionality.
