Hello.
I have some question about the process of loading mesh.
If i use a .X file without vertex normal information, it seems that Ventuz does not compute the normal. But if i load a .X file with vertex normal information, it seem's that the tangent and binormal are compute. Could you explain me the current Ventuz behaviour ?
In fact i would like to know what happens if i use a .dae file with normal, binormal and tangent. Does Ventuz keeps this vertex information or will it compute them ? And are this information accessible from there associated semantic of a shader ?
Thank you.
mesh vertex
Re: mesh vertex
Thank you.
Ok so perhaps i can use UV texture for my purpose. Because i could use TEXCOORD1, TEXCOORD2, etc...
Can i use float4 in collada file for UV (it seems to be possible) ?
Does Ventuz handle multitexture information when loading a collada file ?
if so, how many float are use (two, three or four) and can i retrieve this value in the shader on TEXCOORD1, etc... ?
Re: mesh vertex
Thank you.
Would be very helpful, and in details :
- handle all UV stage with two, three or four float.
- handle binormal and tangent, and have the possibility at mesh loading to choose if Ventuz compute or load the values in the file.
- the choice of computing normal at mesh loading even if there are normals in the mesh.
- when Ventuz compute tangent and binormal, have the possiblity for this settings : partial edge threshold, normal edge threshold and singular point threshold (of course if you use a function such D3DXComputeTangentFrame).
Re: mesh vertex
I forgot :
Could you add the possibility to read/write texture inside the Vertex Shader, and it would be perfect
Re: mesh vertex
Hello.
In fact Ventuz compute normals from X-file, if they are not present.
