Hi All
There are a lot of forum posts about hardware configurations for Ventuz, but I can't find any regarding best Windows setup.
So here I am, starting a little post regarding system software set up
Is a straight forward Windows install ok for running Ventuz?
Does the Windows set up need some 'tuning', if so any infomation on how?
Are there certain processes that you should make sure are not running on a windows installation, or services that can be turned off to gain better performance?
Should you turn off things like 'Aero' in Windows to keep graphics down to a basic level?
Any other tips you can give us regarding getting the best from a system software set up?
Many Thanks
Chris
System setup for using Ventuz
Re: System setup for using Ventuz
Ok basically a straight forward windows installation is a good starting point but there are a few things to care about.
Cheers!
- Windows automatic updates should be turned off. There is nothing worse than a running production system crashing through a windows update.
- It is recommended to disable Windows Notification icons because they can steel the focus in Fullscreen mode and minimize the Ventuz Presenter. A short howto can be found here
- Change the Power Plan from Balanced to Maximum Performance.
- Check your Firewall rules. Take care Ventuz Designer and Ventuz Presenter are different applications and therefore need seperated rules!! So a project that is getting data in the Designer can not work in the Presenter.
- Disable UAC
Cheers!
I would also deactivate all Windows Sounds and deactivate Aero on Windows 7.
Excellent Thanks!
Anyone else got any hot tips??
Optionally I disabled windows defragmentation (msconfig).
Greetings, Stephanx
Greetings, Stephanx
maybe....hav not realy tested...it is a good thing to kill the explorer.exe. after killing the explorer you have no more gui on the screen and so nothing could pop up
take a look here:
http://www.groovypost.com/howto/microso ... -easy-way/
or to stop use a batch file with this command:
@echo off
taskkill /f /im explorer.exe
take a look here:
@echo off
